Transendar Single ended Tranformers and Heyboer Power Transformer
Transcendar Single ended 10Watt output transformers:
Used
Specs:
5 K with 40% UL Tap to 8 ohms
Frequency Response: 20 Hz to 90 kHz +/- 1 dB @ 1 Watt
Maximum DC Bias Current: 90 mA
Primary DC Resistance: 370 ohms
Primary Inductance: 40 H @ 120 Hz
Part Number: TT-312-OT
Large Custom Heyboer Power transformer
USED
Specs:
120v primary,(elecrtostatic shield) 750v CT 300mA, 6.3v 6A, 6.3v 2A, 5v 4A.
electrostatic shield between the primary and secondary
windings. copper flux band across the outside of the
laminations.
Yours, if you pay shipping and promise to put them to good use!
