Trans wires in parallel or series?
This is a dumb wiring question. I'm wiring this transformer for 120VAC US power.
Do I twist the wires with the dot together (red/grn)which would go to line and the other two (yellow/org) together for neutral?
One last question - on the secondary the HV has three wires. 2 red and a yellow. The input to the power supply has two solder pads. Is the yellow center tap to ground?
I measured continuity between the two red one by one and the yellow and the resistance is the same. So yellow to ground?
