Trafomatic RIAA network. Any good?
Is it? The frequency dependent load never allows full swing at high frequencies as it controls the gain. Overload performance cannot be equal.
If you run a "flat" load, yes you get full swing to HF. But then you will run it through a passive high-cut. The signal OUT of that hi-cut will have less swing.
The result is essentially the same either way.
