TQWT with 2 drivers - what to look out for?
I want to do a ML-TQWT with two 3" drivers in a MTM alignment. Line length will be 16". The distance between the 3" drivers is ~ 5". So its no "point source" anymore. Would a simulation with Martin Kings worksheets still give meaningful results?
How about the input values for the worksheet? Since the 3" are wired in parallel, I have to double Sd and Vad and halve Re. But I am not shure about Lvc, BxL and the Q-factors.
Thanks for some suggestions
Rudolf
Thanks Timn8ter,
should have looked at MJKs site in the first place. Seems I´m getting too lazy.
But I am still not shure, if the distance between the drivers in such a short line could be an issue.
Anyway, I`ll get some ply tomorrow and give it a try 🙄
Rudolf
@ weidok
Are you going to use the MHE 280 in your ML TQWT with the Gradient?
The MHE 280 is doing nicely down to near 100 Hz. So it would be a waste (of both speakers) to combine them with the Gradients.
I will put the Mivocs on top of small dipole subwoofers. It´s the most far out combination I could imagine for a small room - so I had to do it. :clown:
It will look somewhat like this (yes, it´s still another ML-TQWT - with a Fostex FF 85K):
Rudolf
