TPAD Devices Kit
So I built this kit (http://tpadevices.com/hifiproducts.html), price seemed fair & I thought it would be a good baseline to compare my own sorry phono-pre efforts against.
Although the preamp is working fine I am experiencing a hum (10mV) on the output. Obviously the first place I suspected was my PSU which is in a seperate chassis connected with a 4-pair cable & 4-pin XLRs.
My B+ is 320VDC and my heaters are at 6.8VDC. Both supplies look very clean on the 'scope. I have experimented with both tube & solid-state supplies for the B+ and with both full wave and bridge supplies for the heaters. All supply designs were checked with PSU designer and performed to the programs' specifications. None of the designs made a difference to the hum level.
I contacted T-PAD but haven't heard back yet. Any suggestions from the brain trust?
Thanks in advance...
PB
PSU is physically 2 feet from the preamp, audio connections are via shielded (one end tied to ground) audio cable. I tried locating a completely seperate B+ supply away from the heater supply, also bypassed my umbelical cable and ran direct wires to the pre, no change.
B+ secondary CT is tied to chassis ground as is incoming AC ground. I tried lifting the AC ground, no change.
Thanks for the ideas...
PB
