Hello everyone
I came across this headphone amp circuit and before I start building it I wanted a second opinion...
I currently have the TPA6120A2 and couple of OPA2134/4134 that I want to use with it.
Here is the schematic:
http://audioworkshop.org/downloads/comp_tpa6120.pdf
The website:
TPA6120 Headphone Amplifier - COMPOSITE TOPOLOGY - DIY AUDIO BLOG, AUDIO WORKSHOP
The website:
If you have valuable headphones I'd definitely use an output capacitor to protect them against a fault condition. An input cap isn't necessary.
If you're concerned about how the thing sounds then I'd pay attention to supply decoupling and have extra PSU filtering for the input opamp so its not directly exposed to the classB hash generated by the TPA.
Thanks for the answer. What will be the best type, and will 1uF do?
1uF will do almost nothing at all. I'd use the lowest ESR electrolytic I could get my hands on. To my knowledge that's a Nichicon HZ series - 1000uF/16V is not exorbitantly priced. If you want to splash the cash you could explore polymers (OSCONs).
I saw the oscons, aren't those caps that are used in motherboards and gpu cards? My work is around them so I'm pretty sure I've seen them. Usually, they are Panasonic if you search them by "code". (small aluminium ones, very hard to remove from pcb ))
Yeah, that's right, these are often used in computing hardware. They're a bit more expensive (like a few bucks a pop), but not prohibitively so, as you'll only need a few. The Panasonics you mentioned are good, but the other Japanese suppliers are fine as well and don't charge the Oscon brand name premium. Have a look over here: Aluminium Organic Polymer Capacitors | Mouser EuropeI saw the oscons, aren't those caps that are used in motherboards and gpu cards? My work is around them so I'm pretty sure I've seen them. Usually, they are Panasonic if you search them by "code". (small aluminium ones, very hard to remove from pcb ))
Hello.
Using caps is nonsense.
This IC don't need it ,but if security is needed you could use relays.
Here a complete board with DIP 8 support and uPC1237 controller to prevent output offset with relay Aiyima TPA6120A2 Hi Fi Headphone Amplifier Fever Audio Earphone Amp Diy Kit-in Headphone Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
A few things:
- I'd skip an output cap but an input cap should be added unless you are certain the sources used will always have an output cap.
- r109/209 are on the low side at 22k, especially with a jfet input opamp. If you add a 10k pot in front of the amp, consider going up to 100k.
- With 10R output resistors, it's not an amp for low impedance headphones, unless their impedance vs frequency curve is very flat. You could replace r107/207 by a lower value resistor and an inductor/ferrite but beware of oscillations. iirc, jcx also suggested to have the 10r isolation resistor inside the opa134 feedback loop (but not in the tpa's) and then having a coil/ferrite to isolate the output.
- despite what the designer says on his website, don't experiment with any opamp at the input, especially not very fast ones. The opa134 is great here because it's kinda slow compared to the output buffer.
- Be careful with the caps after the lm317. You don't want the lowest esr possible here or you'll get oscillation. If you use an RC filter then it's a bit different.
Thanks for the answers everyone!
Now more questions about the amp
I won't be able to find uPC1237 where I live, and also if I purchase it from ebay it will take too long to arrive. Can this be replaced with simple transistor driven relay to delay the output turn on?
I will be using 32ohm headphones, for those, how much should be the resistor value or inductor(if needed) at the output? I've seen this, and just to make sure we are talking about the same. It's output strapped with resistor and inductor connected in parallel right?
uPC1237 detect DC voltage at output, if there's voltage it disconnect the relay.
It has also mute ON.
https://www.promelec.ru/pdf/upc1237ha.pdf
So,add simple relay is useless.
You must find IC for DC protection.
I don't know where you live but the complete TPA6120A2 board come in two week to France.
- Headphone Systems
- TPA6120+OPA headphone amp info needed
