TPA3255 board with IC on bottom side?
The TPA3255 boards from 3e Audio appear to have their amplifier chips on the bottom side. However, they are also higher than 6 cm. Perhaps the electrolytic capacitors can be replaced with ones that have the same capacitance but build lower....?
the maximum height can only be ~6cm :-(
Not exactly what you are looking for, the heatsink is at the top. But it is low profile:
