Tpa3116 + CSR8635 EQ/DSP Settings
Hello,
This is Sreenath, And been a member here for a long time. Hope you all are fine.
Actually I am facing a problem where I bought this TPA3116 Bluetooth Amp with CSR8635 on it, & after I had it installed for my speakers i thought why not I adjust the EQ/DSP to sound perfect.
But, now for some reason I tried to run the PS Tool & Rom Configurator for it and it worked without a problem. But for Some reason the Parameter Manager is not Working.
I tried the CSR8635 ROM Series A03 UFE(CVC) on Win 10 & 7 32bit and it showed this error - The algorithm connected to USB SPI (1003432) identifies itself as E00C @ 44100 Hz, for which there is no available support.
If anyone reads this post please help me get a appropriate Parameter Manager to Control the DSP of CSR8635.
This looks like a clue: Where can I get CSR DSP Equalizer configurator? * Issue #17 * lorf/csr-spi-ftdi * GitHub
"The main trick for the equaliser program is to run it under 32b windows 7 (as un-updated as possible), and to have music playing, otherwise the Kalimba DSP is sleeping (more like dead) and can't be found by the software"
Hope it helps - I'd like to have a go at this myself
Thanks for the suggestion, but I already did that by running it under Virtual Box with Windows 7 32bit, but unfortunately that didn't work too.
I think there might me another version of the program that might work for csr8635.
Thank You.
