Ross,
Did you look at possibility of using USB digital isolator chip as AMD ADuM4160 for upcoming new USB module?
George
George
Ross,
George
Yes, but unfortunately that chip is simply not able to handle the bandwidth we require. We would need a device that could support USB 2.0 High speed, not just full speed.
Besides that we believe we have a much better isolation solution.
We have boards ordered and will be doing some testing very soon.
Russ, I understand that you are about to test a 2 channel board. I'm interested in purchasing Buffalo III + associated parts but only interested in multichannel i2s.
Are you a long way from having a multichannel i2s solution?
Stereo will come first.
After that it will just depend on how much time I can devote to the new design.
DSD over USB support?
Talking about futures. With the release of the SACD ripper for the Sony Playstation native playback of DSD files is on the rise.
Mytek is now shipping their new DAC that supports DSD playback over the USB input.
I am wondering whether the new USB transport could support this as well. Ideally there would be some pin to indicate PCM or DSD in order to get an indication to reprogram the Buffalo.
In any case Jriver just announced support for DSD over ASIO in Media Center 17.
Cheers
Thomas
Cheers
Thomas
There are...
some options: considering how long Russ has been working on TPA's new USB interface, I do not expect him to be able to support direct DSD playback right away, as I do not think XMOS supports this. I would rather see him release the product, than wait another year for DSD.
The dCS DSD protocol (open source) might be easiest to implement, and might be able to work with XMOS, as it seems to "look" like standard 24/176.4 PCM to interfaces.
In the meantime, my recommendation for those who are ripping DSD would be to save your native DSD files for the future, and to convert/copy them to 24/176.4, and tag and them in the PCM format and then play them back as PCM. Alternatively, music player software is now supporting on the fly conversionof DSD to PCM for playback (Foobar, Pure Music, and others).
Although converting the files first would sound better. Although many seem to think otherwise, conversion to 24/176.4 should be transparent with a really good SRC.
Ultimately there will be native DSD playback, but it is in its infancy now...
Sure, I am not suggesting to delay the current product in any way.
However, having a spare output pin might set us up for a firmware upgrade in the future.
Cheers
Thomas
Cheers
Thomas
We have the PCBs for the initial module we need to test. We are just putting together the prototype for that now. Based on its success we will aim to have the main PCB done a month or so after. Once that is tested we will be ready to rock. 🙂
Any progress?
Yes! 🙂
Yesterday I tested a key component and it worked perfectly.
Yes! 🙂
It's always nice when that happens. The number of times you test something and it doesn't work quite as intended😉
Yes. 🙂 It was a pleasant result.
It was crucial that it worked because it was at the heart of how we will be moving bits around.
Russ & Brian,
Any news on the USB board? I am eagerly waiting for news of a successful prototype.
I have been camped out at work the last week or so. Unfortunately have had no time for design work. I plan on attacking the project full force during my Christmas vacation. 🙂
All of the key questions have been answered with prototypes, and now I am ready to finish the the module itself.
Yes. Now that the principle of the teleporter is tested I am just finishing up the core module. Brian and I both are itching to test it soon.
- More Vendors...
- Twisted Pear
- TPA - USB Transport
