TPA metronome and Ivy modules
Hi all,
I have the following for sale:
1 x metronome $50/€40
2 x ivy modules V2.0 (set up for buffalo, but relatively easy to configure for other DACs. Can also be used for V-out dacs and are good enough to drive long ICs or headphones). You need one of these per build, ie 1 for a stereo DAC, whether used SE or balanced $50/€40 each
Standard postage (about 2 weeks to anywhere, no tracking) $5 or €4, registered would be $10 or €8 to pretty much anywhere. Payment by paypal AOK.
Fran
Some pics:
1st IVY:
This was one that came with I think the second batch of buffalo boards. The caps C1, C2, C3 and C4 are soldered in either to the side or under the PCB.
2nd IVY:
This one came with the next batch of buffalo DACs. The layout was tweaked, I think just to accommodate the caps. Anyway, by this time, TPA had changed the caps to slimmer ones so they fit just fine on the board and didn't need to be underneath or off the side. R17-20 were jumpered under the board as per TPA instructions for the buffalo at the time. Easily reversed if needs be.
Metronome:
I never got to use this!! It is here as I received it.
Soldering is good throughout, and both boards are working AOK. All boards are a little dusty, and the underside has a little rosin flux residue (see theres a bit on top of the first IVY board too), but nothing OTT. The metronome comes assembled so no flux etc at all.
Fran
