Can I put two toroid power transformers on top of each other ? I think that I saw somewhere on the internet that someone did this without problems (?)
Zou niet weten waarom niet Jaap, heb het zelf vaak gedaan. Wel een rubbertje ertussen voor de beschadigingen (dwz het voorkomen daarvan).
Jan Didden
(apologies for the online encryption, just felt like it)
Jan Didden
OK, let me see if I can puzzle it out without a translator. Something like, "You don't have to worry, Jaap, I've done this myself. Stick a piece of rubber between them before installing them." How close did I get?
Boe zegt de koe.
Boe zegt de koe.
thanks
I now have enough (Dutch)courage to try
Jaap
jammer dat PIM dit niet meer heeft mogen meemaken
Jaap
SY's get very good at saying boe, isn't he?
Well done, SY...you got the general idea.
Oh, BTW...since you're a moderator😉 I think Jaap started a new thread entitled "Thanks" that I suppose needs to be appended to this one.
Knor zegt het varken....
Cheers,😉
EDIT: and right as well 🙂
Cheers,😉
SY,
Not perfect, but close enough for government work. Of course, Dutch isn't THAT difficult. We have over a million of 5 year olds speaking it easily.
Jan Didden
Jan Didden
"A piece of rubber will prevent damage"?
Is that closer?
Those Dutch have a different word for everything!
Miaow zegt de poes.
(PS my current avatar IS Dutch after all... or was, anyway)
Is that closer?
Miaow zegt de poes.
thanx
guys, now i know where that rubber thingie is used for
jaap
jammer dat PIM ...........
jaap
Yeah,
the only thing with toroids is that you have to watch out that the upper metal mounting plate is not touching any other metal part of the chassis, because ( translating this should be easy ) dat creeert een nieuwe winding .
This acts as a short.
Stacking is no problemo.
It's indeed very sad that Pim.......
- Tubes / Valves
- toroids on top of each other ?
