Toroids in N30 material
Hi all,
I would like to know if the Epcos N30 material is suitable toroids used for SMPS transformer (push-pull).
It is quite hard for me to get toroids in materials other that N30 so I would like to know it these are usables
N30 characteristics
ui=4300
Bmax=380mT
f_min=10kHz
f_max=400kHz
Curie_T=130°C
resistivity=0.5ohm*m
Epcos recommend this material for EMI filter applications
The standard N87 material that Epscos recommends for power electronics applications has the following characteristics
N87 characteristics
ui=2200
Bmax=490mT
f_min=25kHz
f_max=500kHz
Curie_T=210°C
resistivity=10ohm*m
My main concern is the core resistivity, 20 times lower than N87 which will create high losses due to eddy currents.
The value of Bmax is lower but I can always wind more turn on the trafo to lower B.
Do you think that these toroid core are usable for SMPS?
thank you
I have used 3E25 toroids, a material similar to N30, withot problems. The drawbacks are that you have to use a few more turns and a slightly lower frequency, but it's fine otherwise.
Try to search further, I think that there are online stores selling toroid cores made from power ferrite materials (not from EPCOS or Ferroxcube, but from Magnetics, Micrometals, MMG...)
PIN OUT color code from PCB
i was wondering what the color code is for the +12V and +5V out from the PCB to the multi pin connector in the MX9000 power supply. here is what i know so far:
brown = ground
green\yellow = earth
orange = +18V
blue = -18V
purple = +48V
red = +12V or +5V, not sure
black = ground
yellow = +12V or +5V, not sure
can anybody help? i saw the pic from an earlier post but it was the side of the PCB i already know is good!
thanks
