1. Would these Torods be suitable for powering the Chinese Naim 140 clone kits found on Ebay?
2. If so which would be preferred the 500va or 330va?
3. I am assuming these are a dual secondary voltage source 25 Volt X 2 to power the supply's for both channels from the single Toroidal?
If my assumptions are incorrect please put me on the correct path and recommend a toroidal transformer setup suitable for the Naim 140 2 channel amp.
Thank you.
Avel Y236801 500VA 25V+25V Toroidal Transformer - Parts Express
Avel Y236750 330VA 25V+25V Toroidal Transformer
Thank you.
The 330va should be fine as you will be looking at around 40 to 50 watts RMS from those supply voltages.
This thread was similar if it helps,
http://www.diyaudio.com/forums/chip-amps/277967-another-noob-transformer-question.html
