toroidal question
i'm looking at a toroidal transformer with the following description,
44VCT toroidal transformer. This transformers was originally destined for the 240V version of a 160W into 4 ohm audio amplifier. The primaries and secondaries are 18 ga solid copper. There is a single primary and 2 x 22V secondaries at 120V input. Capacity is approximately 150-200VA. Transformers weigh approximately 5 lbs each.
this would be a good start for a chip amp correct? anything else i should look into.
The transformer looks just fine.
