I think of putting a toroidal transformer in PC power supply.
Which distance do you keep between transformer and sides of metal case ?
Not critical, remember they are mounted on the bottom plate (with a pad) anyway.
Just leave enough for a little ventilation, maybe 1/2" or more.
Be careful not to create an unintended 'turn' on the toroid through the mounting bolt and the metal enclosure.
What would be the purpose of fitting a toroidal power transformer (I think a 50/60 Hz one) inside a tight , presumably SMPS PC supply?I think of putting a toroidal transformer in PC power supply.
It's my fear : I have only 1cm aroundBe careful not to create an unintended 'turn' on the toroid through the mounting bolt and the metal enclosure.
reuse parts from dead apparatus : it make a correct enclosure for a linear power supply 😉What would be the purpose of fitting a toroidal power transformer (I think a 50/60 Hz one) inside a tight , presumably SMPS PC supply?
- Power Supplies
- toroidal distance to case
