working pulls from altec laning subwoofers good for preamps
or whatever i got 20 to 40 of em with brakets wires are cut a foot long spec's are
thermal cutoff
brn---grn--7v 0.6a
wht---org--13v 2a
56.2va
thermal cutoff
brn---grn--7v 0.6a
wht---org--13v 2a
56.2va
spec's
sorry here you go
115deg.c thermal cut off
brn-----grn-7v 0.6a
wht----org-13v 2a
56.2va 60hz
not sure if there center tap i can look them over
sorry here you go
brn-----grn-7v 0.6a
wht----org-13v 2a
56.2va 60hz
Karma,
Are these those dual 13V 2A secondaries? Not too shabby--have a couple at home. 😉 what are you looking to get for them?
pic
i would say $5 each thay are heavy so you would want to be in canada there heavy and thay are center tap
pic
i would say $5 each thay are heavy so you would want to be in canada. and thay are center tap. found a working 800va to
Karma,
Those look identical to ones I have, except with hardware:
7v 0.6a
13v 2a
13v 2a
That is, there are two 13V@2A secondaries, not just a center tap. Is that what yours are?
7v 0.6a
13v 2a
13v 2a
I'm in (probably)
Well, just a little bit subject to confirmation of what the actual secondaries are, I'm in for eight of them (and re weight, I am over in Vancouver).
Norman
Norman
I'd be interested in some of those (4?) too. $5 USD or CAD? Take PayPal?
V9B 6E6 (Victoria)
dave
V9B 6E6 (Victoria)
dave
payment
ill need to get setup with paypall $5 can. i gota take one to the post office to get it weighted ill get back to you
karma, how many 13V @ 2A do you have left? I need 12 of them. I live very close by and I will be able to pick them up on thrs. or fri.
I want more!
Actually I would prefer either 6 or 8 of them.
Any info on that 800VA ?
Secondary voltages, weight, asking price?
Thanks,
Sean
Thanks,
Sean
Re: I want more!
I think sean has a good idea here. I'll take 6 or 8 too -- have we cleaned you out yet?
dave
seangoesbonk said:Actually I would prefer either 6 or 8 of them.
dave
no
still got lots left sold 12 so far i gota get setup with paypall
and see how much it is to ship
got lots🙂 the 800va is from a technics amp it work not to sure what the specs are. the main caps in the amp where 90v
so i would say it 70v or 60v supply and it would be center tap and dual
and it is heavy
the batterys in my tester are dead when i test it ill post it
and it is heavy
