the above pic have the same problem ,not direct hf unit.
i sugest stick to the plan ,with the only difference is the hf wave guide.
i was thinking this one .
already send an email to bms to see of we could cross the 4544 driver @ 1000 hz if we use steeper filter.this driver is cheaper then the 4550 and sounds also good.
so your 1 bild is going to be 4 subs 6 midhighs?
ok
ill start this week on the drawing off the midhigh box.
btw,
you could phone or email for prices for the bms 4544 ,and 4550.
maybe you get a discound if you order multyple hf units
us distributer
btw,
HTML:
How To Order
Contact us to order, demo, or for more information.
assistanceaudio@earthlink.net
801.486.2655 home office
801.898.6023 mobile
hi stan
its about 100cm*90 cm*32 cm high.
looking from the top we could make a square box or cut off the yellow area's(waste of space imo)
what you want?
what you want?
can you print this file in a copy shop?
its 30"*42" inch paper size makes life easyer.
its got a 20" line on it to check if its a 1 on 1 copy.
don't realy know papersize and format they can print.
i was searching for a detailed drawing of the sugested horn,then i saw
this horn is a screw on type.we need a bolt on type 😡
so the info is wrong on us speakers.
then i searched for other horns that would fit.
i saw beyma TD 235 but its $80,-
then i found the p-audio PH-2420
whe can make them fit but need s a bit cut of(its abs plastic so that no problem ,i did that a while ago with some abs horns on the cicular saw table ,looked like a factory cut)
they are sold here for €17.-
http://www.mssgeluidstechniek.nl/downloads/prijslijstpaudiospeakers2007.pdf
maybe you could send an email to us speaker if they can order it.
what do you think, remeber there is 2 in each box
That is very kind of you but too much work. Can we try something else.
maybe i can order them here ,and send it to you.
we'll keep it in mind if all else fails.
found an eminence $45.also needs cutting.
or we could do a 1.4"or 2"driver in one horn ,but i have to redraw the box.
lets see what we can find.
- Top for tap
