Hi Everyone,
I have a question about what tools you use to optimize crossovers designed for a Hypex plate amplifier with DSP, like the FA 123 and related. I've managed to successfully build a 3-way center and was very happy with the results but I realize that I may not be using the tools, or taking advantage of 3rd party tools optimally.
In my work I used OmniMic to measure the drivers, and then would adjust the Hypex filter designer by hand for the most part. This was relatively easy because the drivers had a lot of overlap. I realized however afterwards there are some pretty advanced tools for DSP manipulation that maybe I should use. Even Hypex has a way to import the FRD which I didn't use.
I have a new project which is going to require a lot more delicate work. Imagine for instance I have an existing speaker with a -3dB at 55 Hz. Say I want to move that to 70 Hz AND convert to an ideal LR4 high pass slope. Never mind WHY. Are there tools which would make this super easy? Like let me overlay an LR4 HP slope and then create the filters and EQ needed to make it near ideal?
