new forum software has way too many visual elements for me, browsing the threads makes me nauseous very quickly. I know I am quite sensitive to motion and this might not be a problem for the grand majority of the users.
I guess I'm getting old but the forum worked much better for me in the good old times, with just text available, with the directory of the forums on the side. Then you could easily browse the threads to see if there was anything interesting. If there is a way to configure the UI to the same format that it used to be I haven't found it.
Directly up in the user menu (rightmost buttonof left section) there is the item ‚appearance/theme‘, which contains ‘classic‘..
