Tone arm Micro Seiki MA 707 and Cartridge DL 103, happy end !
I had a happy ending odyssey with the Denon DL103 cartridge and its pairing with the Micro Seiki MA 707 arm. 😊
As many of you already know, the fame of this cartridge is great, but to extract its full potential you need a heavy arm, because it was designed for radio stations in Japan at the time (1962!) And they all had the classics. turntables of the time, robust, heavy and with lossy tonearms - compared to arms that were later manufactured for high compliance MM's cartridges - approximately 70/80 decades onwards -, typical Shure V-15 and others .
So after thoroughly reading the following links and debating on the turntable forum without much luck, I decided to go ahead and not settle for the extra mass load of the accessories provided by MS for the MA707. These are, a "rider" and a screw behind the pivot point. The sound was good, but "something else was missing".
I had already tried to add extra weight to the head (6 grams) but that forced me to move the rider almost to the top of the pivot point and bring the adjustment weight - for balanced - to the opposite end, one more full turn and he would fall. !
And the result was not good, there were no improvements with respect to the conventional setting recommended by MS, and also there was a tendency to couple that clearly indicated that the arm was going into resonance at high volumes. (Now that inconvenience is overcome).
So I went to my workshop and looked for several washers, drilled them to 12 mm in diameter, wrapped the back of the pivot point in Teflon to avoid damaging it and once the balance was achieved, a few extra turns of Teflon locked the washers in its place.
As you can see in the attached photos, the rider is closest to the head (the idea was to maximize the mass of the arm at its two ends, that is, to increase the grams of the accessories provided by MS) the head shell now has a Extra lead of 6 grams, (the original is plastic and very light, suitable for high compliance cartridges but not for this Denon DL103 that has a suspension similar to the wheels of a train). The result of all this is fantastic, now I do feel that I entered the "famous Denon DL103 Club", so I will not do any more experiments, the increase in the total effective mass was a great goal.
This now sings for real! The soundstage has opened, the dynamic range has increased, the bass is deep and fast. And I still need to try raising the load of the phono preamplifier from 470 to 1000 Ohms to see if the treble rises something, in the leaflet
that came with the cartridge it indicates that it was tested with 1 Kohms, an apparent Denon contradiction, because in the Attached brochure describe as recommended load 100 Ohms.
While I don't think it makes much of a difference, I'll give it a try, that's easy, just run two Dip's.
It is clear to me then with practice that the "classic problem" of this cartridge is absolutely true, it is not suitable for modern conventional arms. (Lightweight and low effective mass)
I could not imagine that a manufacturer like Micro Seiki would provide accessories for MC - extra weights - that did not get to extract everything possible from the DL103. It is a cartridge with 40 Ohms of impedance, and there are not many with that value, they are usually 10 Ohms. Also "special" is its compliance measurement of 5, taken at 100 Hertz instead of 10 Hz, VE has a resonance calculator for arms and cartridges, I used it a lot of times trying to find the "holy grail" there, but for this cartridge, it does not give a realistic result, because it is developed for cartridges that measure their compliance at 10 HZ.
The idea is to buy new washers, - they look awful, yes - glue them together, and put Teflon back more neatly, I also forgot to weigh the washers, in the next "makeup" operation, I will do it and inform you . 😉
Here the load used for the measurement of FR and that recommended as Denon as the minimum.
There are opinions of supposedly "seasoned" people who claim that the internal impedance of this cartridge is so low that the inductance effect can be neglected! And that can then be used with the "standard" of 47 KOhms for MM! 👎
A nonsense, it seems that they did not know Ohm's Law.
40 Ohms of the DL 103 against 47000 Ohms will make a transfer of energy so great towards the preamplifier that it will leave without perceiving the small voltages generated by the conjunction of the generator and the damping of the cantilever, that is, the treble will be increased but the bass will suffer!
So the practical limit is 1000 Ohms. And if you want to load them with 100 or 470 ohms, go ahead.
