I have been searching hi and lo for a tonearm lift on the Net for some time now. (Of course here as well.) I have also tried to find a cheaper arm on eBay with a removable lift. But to no avail. And I'm not to keen about the idea of having one custom made. Quite expensive.
So my question is, does anyone here have any idea? I don't think I have to mention that making one isn’t an option.
Thanks.
Thanks.
😉 Back in the good ol 70's there was a simple counterbalance tone arm lift marketed by monitor audio, actually l had one but as l had no use for it not knowing what to do with it l chucked it, all it was a simple counterweight arrangement on a pedestal so that when the arm nudged it it would tip over and raise the arm, were people to look at it lying in the bottom of a drawer l'm sure they wouldnt know what it was, think about it l'm sure you could knock one up fairly easily if you think of the principle involved, hope this helps cheers TC😉 OTOH if you check ebay uk one might come up as it was a uk sourced and marketed, product l got mine in '76 when l was in london along with a zerosatat pistol which l still have
Hi PHN,
I bought one over here:
www.frimu.nl
the site is also in English
The armlift I bought is one hole mounting, from tjechie, a bit simple but works fine
Not expensive as well, I think the transport wil be more than the armlift itself.
Succes
Werner
www.frimu.nl
Succes
Werner
😉 glad you solved the problem werner, 😎 l was just trying to suggest something simple cheap and workable without major surgery to your player if l still had it l would have been happy to send it to you cheers TC
It seems I spoke too soon. I had really given up on it, and only asked to be over with it.
Too bad no image though. The price won't kill me if I can't use it. But I do like to see what I buy. Anyway, the important part is that I now know there's hope for me. And in case somebody wonders what I was looking for when looking for an arm with removable lift, try Haddock. Not that I was actually looking for a Haddock arm.
Thanks, guys.
Thanks, guys.
My fault.
I should have understood when the first hits I got at google when searching for "tonearm lift" was the Expressimo lift. Not to mention that I'm a long time owner of Thorens turntables. I guess I just forgot about the Thorens "end lift."
It's so silly. I was originally looking for a tonearm rest. The one I have is in plastic and really ugly. I don't want that one. So I got this bright idea. Instead of looking for a tonearm rest, why not also get a lift? Perhaps one of those lift and rest in one, like on most modern arms.
I know there where lifts made for the Ortofon arms and figured there has to be others. But even if there are, they are probably not that easy to come by these days. So I will get back to just scouting for a rest. I don't need the lift. Should I ever run into one, fine. But I won't hold my breath.
Again, thanks. And sorry for the confusion I caused.
lts okay, we are all human, and make mistakes, actually that was one arm l did not think of the ortofon cheers TC😀
Just ordered something called "SUPRAPHONE- Tjechische pickuplift" from the site Werner Rem linked to. Don't have a clue what it is. But for €5.70, it won't kill me.
- Analogue Source
- Tonarm lift
