Pass DIY Addict
Joined 2000
Some time ago, I remember coming across a heatsink performance simulation. I can't seem to find it now, but I think it let you specify your heatsink parameters and thermal load, positioning of output devices, etc. Anyone know of such a resource?
Thanks!
Thanks!
If I were you are going to be using large heat sinks I would get a piece of 3/16 copper plate a little bit smaller than the heatsink surface and thermal goo it and screw it to the heatsink to spread the heat over more surface area of the heat sink.
Pass DIY Addict
Joined 2000
Thanks MEGA-amp! That's the one I was thinking of!
Kilowatski - I just ordered some of the sinks that I linked in my first post at the start of this thread. They are about 6.5" wide and 10" tall each - 4 per monobloc. A number of people here used these same sinks for Aleph 2's which have the same power dissipation. I hadn't considered using a copper plate before. What are some likely sources for the copper - I've never looked for this before?
Edit: <Cough> I just found some copper sheets on the McMaster web page: $200 for 6" by 36" of 3/16" thick! Yikes! That size would be just enough for one amp...
Eric,
I built an Aleph 4, and am in the process of building 2 Aleph 30's to run the 2 front speakers in my stereo/surround system. Let me warn you about the heat generated by one Aleph 4. I use a fan in the room next door, and route the air under the amp which lives in a purpose built wooden rack. The blower is a 220 volt running on 110 to slow it down and make it quieter. The heat from the one amp eventually warms my 16 x 19 foot basement. I figure with the additional 2 Aleph 30's, I will have to close off the furnace grates that feed the room when I have the amps on. With 5 amps, you will have to actively manage the heat or it will run you out of the room. I am near Chicago so I get 7 months of cold weather and the basement is always cool, until I turn on the Aleph!
Good luck
Don
A music playing Heater , Nelson should change the name to Aleph F50 deg C....😀
Steve, that is good info on the filled epoxy powdercoat!
There is some benefit to going with a powerdercoat solution in terms of "look and finish" compared to the work required on raw aluminum... Plus, in theory I can shoot it myself!
Any links to this material you know of??
I will check for links. We used it at a company I once worked for, but I was in product development, not the paint department.
