16x MJ2501 PNP Darlingon
TO-3 10A 80V 150W
7 are unused. 9 have been greased and used slightly. Bought from mouser about 1 year ago.
http://eu.st.com/stonline/books/pdf/docs/5080.pdf
19x House numbered IRF9130
11 unused 8 greased and used slightly. I got these surplus.
2x Pecor 2N5686 NPN
50V 50A 300W - Came on heatsink I bought off ebay.
I will include mica insulators and screw insulators with the TO-3's
Lambda 5V 10A swithing supply. Enclosed in perforated metal with teminal strip for connections. 120V. Very high quality. 10000uF on output
Lambda 12-15V adjustable 0.5A open frame linear supply. Solder connections 120 or 240V in.
15uF 2000V capactor - CSI capacitors paper in oil. No PCB's. I will not sell this to anyone unless they know what they are doing. This is a dangerous capacitor. Maybe good for some tube stuff?
2x Speedotron MW24Q flashtube. Pins have been soldered to. May be a generic brand. 2400 J rating. Extremely easy to trigger - a disposable camera trigger works!
I will try to post some pictures later.
make an offer on any or all of this. I would prefer to sell within the US, but could consider otherwise. I can accept paypal.
Darrell Harmon
TO-3 10A 80V 150W
2x Pecor 2N5686 NPN
Darrell Harmon
dlharmon said:15uF 2000V capactor - CSI capacitors paper in oil. No PCB's. I will not sell this to anyone unless they know what they are doing. This is a dangerous capacitor. Maybe good for some tube stuff?
Darrell Harmon
Why is it dangerous? Do you send it express after charging it?
/UrSv
