Hello, I got this TMA T1000.1 rev2.0 amplifier had exploded c208 c201 c203 100v 10uf, C207 5.6uf 100v, R202 10ohm, Replace all the parts and turn on it works but sometimes at high volume it is protected connected to 13v 2ohm, what could be what's wrong?
What is the part number of the IC next to the TL594?
It's possible that the ICs you listed are those part numbers but it's not likely that those components are causing the problem if the class D waveforms are good.
Why are the traces near the large blue capacitor bare?
The beige fixative can cause problems. It should be removed, especially if it has darkened.
Las pistas están desnudas porque tienen pegamento y al quitar el condensador original c207 se desprendió, no entiendo que sea, fijador beige, pegamento amarillo?
The tracks are bare because they have glue and when removing the original capacitor c207 it came off, I don't understand what it is, beige fixer, yellow glue
- General Interest
- Car Audio
- TMA T1000.1 Protect
