TL084CN vs AD731
Hey guys, I'm trying to modify my pre-amp using TI084CN to AD731. Except from comparing the specifications, I'm not sure if the AD731 will fit as a direct replacement to TI084CN without any modifications to other components or values used. Can anybody enlighten me please?
Thanks for the reply. It is indeed AD713 and I'm still unsure if I should change to AD713. I mean, do I need to do any other modifications to the circuitry or just do a direct replacement to TL084CN?? Any better idea on what chips to use?
Is it worth to change LM339N to CMP04? Will there be any sonic improvement? I've recently replaced my CDP NJM2114 to AD8065 and is very satisfy with the result. I'm now thinking of changing the NE5534N to AD8065 as well. Is there any better suggestion?
Sorry guys. Everything will depend on the source level to find a difference between any quad IC designed in the '80s or '90s.
The AD713 comes from the late '80s, and it's still considered one of the best there is. So I think it will all depend of the implementation.
The AD713 is better than the TLO84 though, and certainly more modern.
Now if you will compare a quad with single chips or even some dual ones, then that's different. You will find many chips around, DIP or SMD that will certainly improve on any quad.
