TKD pot upgrade
Hi all, looking at changing my alps pot to a tkd.
As per attached pdf. Assume 1 in input 2 is output and c is earth?
First time at this, so just need a little guidance.
Thanks.
Ps. Worthwhile upgrade?
Graham if your anywhere near Sheffield you're welcome to pop round to hear what the tkd pots don't sound like. If it has any signature I can't hear it.
When I listened to my first TKD I was struck that it had a background silence like no other potentiometers I've had the others including a stepped NLE same as the DACT.
I experienced the silence as a TKD signature as it leaves the signal unchanged.
You may think that they have become expensive, but considering that everything else has become more expensive, it is just acceptable even if you wished you bought for all the projects you have when they were cheaper.
Can anyone comment on the attenuation curve and what the bottom of the range is like compared to the common Alps potentiometers?
Certain models from TKD are specified at attenuators (ladder type) rather than faders, and the atenuators cannot be used in circuits where potentiometers would be used. I’d be interested in learning what benefit they might have over the potentiometer versions, as a volume control.
One thing I notice and find unexplained is the “50dB” spec on the ladder attenuators. Is that the min attenuation possible, or is that the attenuation at half rotation?
Thanks.
Yes, definitely. Once I tried the TKD pots, I never considered Alps again. They are great. My experience re tracking is also great - never bought one that was not tracking correctly.
Have a look here:
https://www.hificollective.co.uk/sites/default/files/tkd-2511-potentiometer-info2_0.pdf
https://www.hificollective.co.uk/sites/default/files/tkd-2511-potentiometer-info_0.pdf
Reactions: kouiky
