Tiny teenager speakers
diyAudio Member
Joined 2007
Actually still only 11YO but rapidly approaching that time when you seal them in a 44 gallon drum and feed them through the bung hole. Still I promised and she wants a set of speakers that sound like real guitars. Also it's the speakers than need to be small as this femme fatale in training is fast approaching 175 tall.
I think it is about time I used my collection of tiny drivers. Years ago somebody on the forum gifted me a pair of 150mm 4R woofers to use in a project like this
So 4 * 55mm full range from an LG HTIAB system, one pair 4" woofers with reasonable bass and Audax Mylar tweeters, WMTM
The Audax Mylar are probably OK with a small cap in series say around 2uF or smaller and I would like to keep costs down by using as much stuff from my stash as possible
So my question is this. Do I make a proper 3-Way or use the little woofers full range with a .5 boost?
I just ran a sweep and they seem to go from ~100Hz to about 15k, nothing below 100 but the woofers have output down to 30
So just a cap in series before the small driver around 500 or a second order electrical a bit lower at 300? All values near enough good enough and standard values? Input appreciated on another small fun project
Rate she's going, she's going to be ~ 6 ft/183 cm like mine.
Well, need to do 80 Hz flat out to 1250 Hz, then whatever tonally matches up out to ~5 kHz, so personally would do 3 way since they're all small drivers and without getting that 80 Hz rolling off to 40 Hz/F24 it'll sound like an AM radio.
~[80^1250]^0.5 = ~316 Hz XO, especially with a boosted low end.
GM
I hate them
Yuck
Thin and tinny so back to the drawing board and sell these at a garage sale although they might be usable as a tweeter just not good enough for GDs golden ears
Luckily I have a back-up plan and better midrange on hand
These are better
Still surprised by the bass from that 5" woofer
Asymmetric XO at ~280 and 3500
Strange second order on the woofer and still playing with values there, but they actually sound like "real guitars" I might actually splurge on a decent capacitor for the top end seeing as the component cost blew out with a 9mH coil on the midrange.
Now to get some cabinets started, woodwork has always been my weak point, then I will finalise the XO
I can hear a definite difference when I swap between the cheaper yellow cap and the Jantzen cross cap.
Aussies might recognise the tweeter as coming from Dick Smith many many years ago when closing down; $30- a pair, only about 88dB but that means padding down isn't essential with this tiny midrange
Probably just another monkey coffin. Although the baffles is big enough to take another small woofer if I had one. I'll probably just cut 150mm off the height tho, compact is better in a small room
