First of all let me point out that I'm well aware that the sensible way to design a speaker is to start with the drivers to be used, then choose an alignment and design an enclosure, not the other way around.
However, for this particular project I have to choose drivers (6.5" & tweeter) based on an existing cabinet with some nasty restrictions (don't ask). The problem is that due to its design the cabinet has a very limited volume (3 liters) and the front baffle only has room for either a tweeter OR a port (maximum 40mm dia and 20cm length). Furthermore, the tweeter would have to have a fascia no more than 50mm in diameter. F3 doesn't have to be very low though as the system will be complemented by a sub, but the lower the better.
I would very much appreciate if anyone more experienced in the art of speaker building than myself could help me with some advice - which would you recommend out of the following three options:
1) 6.5" woofer and separate tweeter in sealed box
2) 6.5" coax in ported box
3) 6.5" fullrange in ported box
Knowing that:
- Drivers can cost maximum $200 for a complete pair
- Sound quality is more important than SPL
- QTC should (ideally) end up between 0.6 and 0.8
- System has to handle up to 60W (at least)
I have spent a couple of weeks looking at different drivers but I can't seem to find a solution that would acheive the desired results. At present I'm leaning towards the coaxial option as it would allow me to fit a port and it has proved difficult to find a separate tweeter within the required dimensions.
Any creative suggestions, recommendations or complaints would be greatly appreciated!
Lomax
Knowing that:
Re: Tiny 2-way design w. 6.5" woofer
I can't think of a reason why either approach couldn't be used.
I think that you're right to say that the limited volume is the problem, particularly if you're talking 3 litres. I don't know a 6.5" driver that could go low enough to crossover to a sub in a 3 litre cabinet. Maybe in a car you could crossover at a higher frequency.
Steve
Lomax said:First of all let me point out that I'm well aware that the sensible way to design a speaker is to start with the drivers to be used, then choose an alignment and design an enclosure, not the other way around.
Steve
You could use an SEAS P17REX COAX/F ($83 ea) in a 3 litre sealed enclosure with a Q of 0.8, which would naturally roll off with an F3 of 100Hz. Then use the sub from 100 Hz down. This would be like a satellite system. There's a shielded version available for use next to a CRT TV too.
I don't know anything about this driver, but SEAS is normally good stuff and it looks suitable on paper.
Mick
Mick
Kanga said:You could use an SEAS P17REX COAX/F ($83 ea) in a 3 litre sealed enclosure with a Q of 0.8, which would naturally roll off with an F3 of 100Hz. Then use the sub from 100 Hz down. This would be like a satellite system. There's a shielded version available for use next to a CRT TV too.
This driver is fairly highly reguarded & one i'd like to try out sometime. And Phil Abbate has done a project with this driver and figured out an XO & such-- Diamond Monitor article.
For use with a sub you don't want a ported box. You might want to make it aperiodic thou... lower the Q a bit & flatten the impedance curve.
dave
Take a look at this project: http://member.newsguy.com/~stigerik/html/gnurk.htm
I know this guy, he is a experienced designer, se his Griffin speakers.
Edgar
Edgar
at 3 lites would a 5" driver (co ax or otherwise ) be better. yes your Sd would be much less and that might limit your max SPL at say 100Hz but otherwise a 5" might be better mated to such a small box.
- Tiny 2-way design w. 6.5" woofer
