Anyone besides me having problems logging in to Tidal?
I have Nativ music streamer all other digital service working just fine but despite re-loading the app Tidal refuses to connect. I've reset the password and can listen to Tidal on PC and Apple phone just the Android base streamer that's failing.
Any Ideas?
Any Ideas?
Tidal have changed the api-token. Nothing much you can do unless you are techie enough to use a network sniffer to find a new token. And that will only work until the next time they change it.
It's still possible to stream to Android with Bubble UPnP though. In Bubble, select the 'Local and Cloud' library -Tidal and then select your renderer on the 'now playing ' screen.
You will have to keep your Android device running though.
Too late to edit, but my post may seem a bit confusing because I didn't notice that you are using an Android streamer. I'm using Bubble UPnP on an Android tablet to stream Tidal to my Moode player which is on a RPi.
I was also able to use Linn Kazoo on my Macbook but that's no longer possible.
I'm not familiar with your Nativ device, so none of the above may be much help unfortunately.
Edit: Maybe the makers of your streamer could help, if Tidal integration is an advertised feature.
