I am trying to understand why ti did certain things in there evm design linked here
http://focus.ti.com/general/docs/lit/getliterature.tsp?literatureNumber=slou220&fileType=pdf
1) Like i don't understand why the common mode resistors are 4.7kohm, I use R9=R10=R11=R12 = 1/(√2 • 2πfCC1) this formula i got off this page Understanding output filters for Class-D amplifiers | Audio DesignLine
in which case it is much lower for this design more like 3-6ohms, depending on fc. Can someone explain the rational 4.7kohms? Thanks
It's looks like some of the TI chips in this family have internal pull-down resistors for the bootstrap capacitors (see Figure 1 in the TAS5709 data sheet), and maybe some of the chips don't. So R9-R13 are pulldowns for chips that don't have them internally. I'm guessing...but they are the wrong size and value to be part of the output filter.
TPA3122D2 CLASS D AUDIO POWER - Audio Amplifiers Forum - Audio Amplifiers - TI E2E Community
The 4k7 ohm resistors are used to discharge the dc blocking cap when the amp is turned off, either by removing the power supply, or putting it in shutdown. This helps with pop performance, so the absolute value is not critical.
