Threshold FET nine
Last year I experienced some “hiss, crack, pop” noises from the pre.. every two minutes or so.
I did not use the pre since last year.
I hooket it up a few days ago, played some music (knowing the noises would be in the background) ..
Well.. today, I only listened to it the last couple of hours, with no music playing (if the music is playing I would not be able to hear it!, its that low)... I wanted to hear these noises again ... but they are completely GONE right now! :scratch2:
Will it maybe come again you think?
I may have changed my setup a bit since last year/last time playing with the FET nine.
I am not sure but maybe I also got a new fridge since last year, don`t remember exactly when - could this be the cause.. or what could make the noises go completely away?
I made a thread last year about the problem.. and never found a solution. (But thought I did for a while).
Regards René
Im sorry..
But I meant noises thru the speakers, not the pre.
- will that change your perspective?
Its working right now.
I believe all my cables were thoroughly put into place at that time, I always double-check.
Regards.
