From my remember about 1 year ago I had post...
http://www.diyaudio.com/forums/showthread.php?s=&threadid=41104&perpage=10&pagenumber=4
I found a lot of sorce of them schematic / PCB / parts, does anybody want to make them to DiyAudio Project ?
I'm notice in parallel DUAL JFET input(original are NPD5566 but I uesd 2Sk332), better than 1 pair DUAL JFET ? I can't find it's difference.
What's quality of 3N172 mosfet, Could I use BS250 insted of it ? (now I used SMD irfd 9120)
I had searched (real) THRESHOLD FET 10/HL PCB for many months, I'm very tired, Could anybody decide to work with me ?
Regard
analog guy
Regard
analog guy
What's different between Threshold Fet-10HL & E
AHHH...I seen Fet-10HL of Threshold production line
NS-10 Stereo Preamplifier (1977-79)
800A 200 Watt/Channel STASIS Stereo Power Amplifier (1975-77)
400A 100 Watt/Channel STASIS Stereo Power Amplifier (1976-79)
4000 200 Watt/Channel STASIS Stereo Power Amplifier (1977-79)
SL-10 Stereo Preamplifier (1979-81)
CAS-1 75 Watt/Channel STASIS Stereo Power Amplifier (1979-81)
CAS-2 125 Watt/Channel STASIS Stereo Power Amplifier (1979-81)
STASIS-1 200 Watt STASIS MonoBlock Power Amplifier (1979-81)
STASIS-2 200 Watt/Channel STASIS Stereo Power Amplifier (1979-81)
STASIS-3 125 Watt/Channel STASIS Stereo Power Amplifier (1979-81)
FET-1 (two series) Stereo Preamplifier (1981-85)
FET-2 (two series) Stereo Preamplifier (1981-85)
SA-1 160 Watt STASIS MonoBlock Power Amplifier (1984-88)
SA-2 100 Watt STASIS MonoBlock Power Amplifier (1984-88)
SA-3 50 Watt/Channel STASIS Stereo Power Amplifier (1984-88)
S/150 (two series) 75 Watt/Channel STASIS Stereo Power Amplifier (1982-84)
S/200 (two series) 100 Watt/Channel STASIS Stereo Power Amplifier (1984-86)
S/300 (two series) 150 Watt/Channel STASIS Stereo Power Amplifier (1983-88)
S/500 (two series) 250 Watt/Channel STASIS Stereo Power Amplifier (1983-88)
S/1000 (two series) 500 Watt STASIS MonoBlock Power Amplifier (1984-88)
PCX (-X10) Stereo Electronic Crossover (1987-89)
FET-9 Stereo Preamplifier with Phone Stage (1986-89)
FET-10Pc Stereo Phone Gain Stage (1986-89)
FET-10HL Stereo High Level Preamplifier (1986-89)
SA/3.9e 60 Watt/Channel STASIS Stereo Power Amplifier (1990-94)
SA/4e 100 Watt/Channel STASIS Stereo Power Amplifier (1989-95)
SA/6e 125 Watt STASIS MonoBlock Power Amplifier (1990-94)
SA/10e 175 Watt STASIS MonoBlock Power Amplifier (1990-94)
SA/12e 250 Watt STASIS MonoBlock Power Amplifier (1989-95)
S/160 80 Watt/Channel STASIS Stereo Power Amplifier (1992-94)
S/250 125 Watt/Channel STASIS Stereo Power Amplifier (1992-94)
S/350e 150 Watt/Channel STASIS Stereo Power Amplifier (1990-94)
S/450e 200 Watt/Channel STASIS Stereo Power Amplifier (1990-94)
S/550e 250 Watt/Channel STASIS Stereo Power Amplifier (1990-94)
S/1600e 750 Watt STASIS MonoBlock Power Amplifier (1989-1994)
DAC1e Digital to Analog Convertor (1992-96)
DAC2 Digital to Analog Convertor (1995-98)
FET-9e Stereo Preamplifier with Phone Stage (1990-94)
FET-10Pe Stereo Phone Gain Stage (1990-98)
FET-10He Stereo High Level Preamplifier (1990-94)
T 2 Remote Control Stereo Preamplifier (1994-98)
T 3/T 3i Remote Control Stereo Preamplifier (1994-98)
T 50 50 Watt/Channel Stereo Power Amplifier (1994-98)
T 100 60 Watt/Channel Stereo Power Amplifier (1994-98)
T 200 100 Watt/Channel Stereo Power Amplifier (1994-98)
T 400 150 Watt/Channel Stereo Power Amplifier (1994-98)
T 800/T 800D 200 Watt/Channel Stereo Power Amplifier (1996-98)
I need some help from all members. My friend has got one threshold model FET ten/hl. The power supply is totally damage and I am planning to rebuild one for him. Anyone got a schematic?? Thanks in advance.
Thank you for the schematic. There is an individual power source unit separated from the FET10/HL, few more questions want to ask :
1) what is the +/- output voltage from the power source unit?
2) and what is the reference voltage (+/-) from the regulator board??
Thank you for your input and much appreciated.🙂
according to previous posts output from reg is +/-12Vdc
you need at least 15 steady volts in all circumstances for input to reg
use 2x15Vac xformer and you're good
yeah ...... solid fact!
shown on right side of p5 of pdf I posted
not exactly clear , but it also shows regulated rails are +/-18V , same page
- Threshold Fet 10/hl Opinion ?
