Threshold 400A Grounding Problem
I have owned this amp since 1978 or 9, during which time I always believed that the ground loup was caused by the connection of the TV cable to the rest of the system. I used a cheater plug so that the amp could not ground to the house electrical system. The amp has worked fine in my, and others', systems thus.
However, I am of an age when I am divesting, and wonder if anyone has any idea how to correct this gounding issue to aid my sale, or should I just sell it as is?
Yep, it's the TV or cable. I had that problem. So I took the digital out from the TV using optical to a cheap DAC with optical digital input. Good enough for audio-video, and safety ground still intact. Problem solved.
