Just got back my Threshold 4000 amp and it is tripping the circuit breaker when I turn it on. Any special kind of power strip or surgemaster I should use or look at a higher value circuit breaker? After I turn off the other devices on the same circuit I can turn it on. Thanks.
As Rayma said. Overloading the circuit. Would be best to put it on a separate breaker. Licensed electrician may be needed to make sure the breaker panel and circuit can handle the surge.
- Threshold 4000 firing up
