Ok,
Here's something I am not entirely sure about. Let's say I have three 4Ohm 10" single coil speakers.
Do I wire them up in series, or series-parallel?
TIA
Tim
Edit:
Hmm, from what I understand currently, if I run them parallel, they should put 4Ohm to the amp. If I run in series, they put 12Ohm to amp (?) and run in series-parallel, it varies or uses the highest Ohm (if I mixed with a speaker with a higher Ohm).
TIA
Tim
Edit:
Ok,
No big amp here, here's what I found in specs:
4 ohms @ 12/13,8 V 75/100 watts RMS
2 ohms @ 12/13,8 V 110/150 watts RMS
bridge at 4 ohms @ 12/13,8 V 220/300 watts RMS
If this is the case, my best/safest option might be to do series-parallel, so I could hook up bridged at 4Ohm.
If I run parallel, I think it makes it 1.5Ohm thereabouts (4Ohm divded by 3).
So I'm unsure about doing bridged with series-parallel, or run parallel on one channel.
Tim
Tim
your only safe equally powered option with the amp and speakers you have is going to be a series connection. Granted your amp will probably not make a lot of power into a 12 Ohm load. You will not hurt anything if you connect one speaker to one channel and parallel the other 2 speakers to the other channel of the amp, But the speakers will not see the same amount of power. If you do it this way, you really need an enclosure with 3 separate chambers.
Ok, well it all depends on the stablity of the amp, meaning... what is the amps lowest omh load it can safely handle? I'll break down the connection loads for you. If you run all three subs in parallel the current ohm load will be 1. If you run all three in series-parallel the ohm load will be 4. As for running all three in series... that isn't possible to do. However you can run four voice coils in series. And if that were to happen the ohm load would be at 16.
I Am An Idiot said:your only safe equally powered option with the amp and speakers you have is going to be a series connection. Granted your amp will probably not make a lot of power into a 12 Ohm load. You will not hurt anything if you connect one speaker to one channel and parallel the other 2 speakers to the other channel of the amp, But the speakers will not see the same amount of power. If you do it this way, you really need an enclosure with 3 separate chambers.
This type of wiring setup is possible to run. So as far as it not being possible to run 3 voice coils in series(as I stated earlier) I stand corrected. However, running a setup such as that isn't an option that I would ever consider doing. Thus, anyone who understands resistance and how it effects the power and performance of an amp, would agree that running 3svc subs to a 12ohm load isn't an effective or practical application in any way at all. So that is why I stated earlier that it couldn't be done. Because in all reality... it shouldn't be done.
I'm not looking to start an argument, or to be condescending. I disagree with such a blanket statement.
A 12-ohm load will cause a bridged stereo amp to produce the same power as it would into a 6 ohm stereo load. That can be perfectly practical and effective, depending on the system and your goals. I've used plenty of 6 and 8-ohm drivers as single drivers per stereo channel with great results.
In reality, it's a perfectly fine option depending on the circumstances.
Likewise,
I *personally* would not consider running a series-parallel connection with an odd number of identical drivers. Power will not split be evenly among the drivers, and (unless I was trying to do some sort of band-specific augmentation) that would be unacceptible to me.
That's no to say it can't be effective, practical, or it shouldn't be done.
To the OP's question-
If this were my amp and 3 identical 10" 4 ohm woofers, I'd either:
1)wire them in parallel and see how long the amp would run an effective 0.67 ohm load
2)wire them in series and deal with the power loss, or most likely
3)buy one more identical woofer and parallel two per channel
you can't put 3x 10" on stereo amp... not any normal one... get sub amp stabil on 1R and connect all 3 in ||
From what I know, to find the resistance of the 3 in parallel, you need to write them as 1/R (resistance), add them together, then do the 1/ again, so
1/8 + 1/8 + 1/8 = 3/8
Therefore the resistance would be 8/3, or 2.6666666666 ohms, not 0.67
Which means the amp should be happy.
chris661 said:From what I know, to find the resistance of the 3 in parallel, you need to write them as 1/R (resistance), add them together, then do the 1/ again, so
three 4Ohm
three 10inch 4ohm drivers each with their own amplifier, will likely perform better than any combination that couples the speaker drivers together.
no,
three separate amplifiers driving three separate speakers all fitted to the one box.
There is an argument that each driver should have it's own box, but not everyone agrees that better performance is obtained doing this.
how would you set 3 amps exactly the same? If you had one amp, one box for all drivers would be better, yes, but not for 3 amp, each driving its own driver
3 X 8 = 2.6666 3 x 4 = 1.33333
luka said:you can't put 3x 10" on stereo amp... not any normal one...
Sure you can. Wire them in series and bridge the amp mono. Any 'normal' amp would be able to drive this load.
Absolutely, just as you clarified before.
And bridged mono would be effectively equivalent to 0.67 ohm stereo load. (I know some folks don't like to say it that way.)
how much does exactly the same mean?luka said:how would you set 3 amps exactly the same? If you had one amp, one box for all drivers would be better, yes, but not for 3 amp, each driving its own driver
same tolerance as the drivers?
Or ten times closer tolerance than the drivers?
Or, something else?
To get most out , all has to be driven the same, if you just have to have something, anything will do, even by ear 😉
ok check this out... running three drivers in series parallel with an ohm load of 12 isn't practicle inless your setting it up for some kind of a competition. to recap on the original topic... i would recommend running the three drivers you have in parallel. if your amp isn't 1 ohm stable then i recommend either... 1. buying an amp that is 1 ohm stable. or 2. buying new drivers that will run in accordance with your amp.
i also am not trying to cause a conflict between opinions. that is why we all are members of this site. to learn and to educate in the matters of audio performance. i have been installing car audio and mobile electronics since 1999. i have a vast knowledge of products and technique. running three svc subs to a 12 ohm load set up isn't in the benefit of the overall performance of the sound system.
- General Interest
- Car Audio
- Three 10" 4Ohm subs, wired in series or series-parallel?
