Thoughts on making J-FET Preamp of a 2N5546
Hi
Ive taken apart an old oscilloscope and found some interesting old gold pin BJT and JFETS (and some opamps i havent looked into yet.
I have built a JLH 1969-ish clone before and a normalt simple BJT preamp, and been tinkering with electronics a alot, but not in audio very much.
But I would like to try this as an input stage to JLH or maybe a separate preamp.
It beaing a dual jfet should mean they are pretty well matched up?
It is a 2N5546 that a find most appropriate of what I have.
Link to datasheet: 2n5545-7.pdf PDF datasheet. ALL TRANSISTORS DATASHEET. POWER MOSFET, IGBT, IC, TRIACS DATABASE. Electronic Supply. INNOVATION CATALOG. Service
I have done alot of searching and havent found anybody using this, I read up on what resistors etc would be appropriate i believe. But what I just seem to not find any good info on is what makes a particular JFET good for audio purposes?
Is it even probable that a osciloscope jfet would be of any use? It was a crt oscilloscope but i dont believe it was part of that circuit but somewhere near the inputs.
Sorry if any grammar is messed up, english is not my first language.
Would very much appreciate some tips in the right direction.
Best regards,
Lars
You haven't found many using this dual fet as fet technology has advanced considerably with fets designed for audio having vanishingly small amounts of noise etc like-
Linear Systems || ULTRA LOW NOISE P-CHANNEL DUAL JFET
Even the one you posted has been superseded.
A JLH 1969 clone using j-fets ?
Do you know how many audio enthusiasts think John,s original design OR his slight modifications to it represent a high level of audio satisfaction ?
To such an extent many well known audio design engineers have built it and applauded it in tech magazines like EW inhabited by guys in the industry.
Sure you can experiment but don't expect the same quality of reproduction that circuit is a world classic.
Yeah this is obviously not the absolute best stuff, I'm aware. I just got into building audio electronics and I try to see what I can make with stuff I have around.
But youre right, I saw some expensive looking old parts with gold on them and saw prices on ebay without looking very close at the specs.
I do have some input fet opamps from amps and theres some K373 JFET in an old amp pcb. I will try them instead.
And I dont need a preamp really for signal level, I guess a buffer is more what Im after. More specifically I was looking into getting more and consistant input impedance while building a passive input selector and attenuator.
Does that sound like a reasonable idea_
