Thoughts on B&C TBW 100-4 vs. TBX 100-4
Hey folks.
Really interested in your opinions/ measurements on these two drivers.
I haven't found much info on the tbw's as the tbx's seem very popular.
I will be using the TBW's in a double bass reflex box temporarily with aspirations for something else later but i have a double 18 box already built and I'm doing a small fest in two weeks and need it.
The current box is 6 cuft ×2 after port and driver displacement.
Thanks Art. I was hoping you would answer.
Now, have you had any experience with it. I'm wondering if i should spend the extra $150 per driver and get the 18SW115's instead? Will the extra 200 w rms and 2mm xmax make a huge difference?
Thanks for your knowledge!
I'm using the BC 18TBW100-4 in a pair of Keystone (Tall) cabinets, they are a very capable driver. Given more power, the 18SW115 is a bit more capable, and also can use a slightly smaller box.
Not a huge difference, probably less in terms of % than the cost increase.
Okay. Thats great. I was looking for a subjective opinion from trained ears. Thanks for your time. Like i commented to you before I'm heavily leaning towards keystones as a final home for these as it is an uncomplicated build with proven results. Have a good one!
