Has anyone had experience with the 150W EYE MT150D 6500K Color Arc 96 CRI Metal Halide Lamp?
http://www.businesslights.com/product_info.php?cPath=185&products_id=1075
The lamp looks spectacular in terms of color and luminosity even if the wattage is a bit low. The cost is a bit higher than other bulbs, but the possibility of a color range this high would make it worth while.
Any thoughts?
Any thoughts?
even better: it's small
From the description, it is a T13 bulb which would be 13/8 of an inch in diameter. From the picture, I estimate the arc length to be only about 17 mm. That is great!
Too bad it is so expensive!
How about this one
The OSRAM SharXS HTI 400 W/D3/75 is a compact double-ended ('D') metal halide lamp of the SharXS family. By the extra short arc of 3 mm ('3'), this lamp has a very high luminance and provides a high output for intelligent entertainment lighting. The “eXtreme Seal” technology enables higher pinch temperatures up to max. 450°C. Being doubled-ended (with pre-focus base) the lamp is hot restrikable.
Specifications
Average Life: 750h
Base/Cap: SFc 10-4
Colour Temperature: 7500K
Luminous Flux: 26000lm
Equivalents: OSHTI400WD3
Specifications
Average Life: 750h
Base/Cap: SFc 10-4
The Iwasaki lamp arrived and yes, the arc is very small. Also, found out that it is available with a G12 base; this makes it the lamp to have. Now if only I can locate a vendor.
The Medium base lamp I purchased has an average life of 12000 hours but the smaller G12 base unit (MD150/G12) has only 6000 hours.
javascript:smilie('
bullseye
javascript:smilie('
bullseye
