Bought 2 Thorens Turntables for just 35 Euro this week! A TD166 and a TD160 MkII, both unmodified, damaged, incomplete but still useful after reconditioning, i hope.
First problem is a armlift that doesn't move up and down. The construction underneath the lift works fine, its the cylinder that's giving troubles
Has anyone suggestions how to solve this problem properly?
hallo landgenoot 🙂
heeft u al geprobeerd om de lift uit elkaar te halen en schoon te maken
hij zal wel vastgekoekt zitten
en daarna een beetje olie erop en dan zal de lift wel weer werken
groet maurice
groet maurice
hello
oke i will try
but my englisch is not very good !!
what i was trying too say is
try too take it apart ,clean it and maybe some oil
and it will work fine 🙂
greetings maurice
oke i will try
greetings maurice
