Hi All:
I have a problem with my TD147 Jubilee. The auto stop doesn't work properly. Since this is one of the reasons I bought this 'table, I really want it to work as designed. So...
The problem started when the LM324 quad op-amp (Z101) fused and took out one of the rectifier diodes in the power supply section. This presented ~20VDC to the whole circuit and cooked the MC3400 JFet op amp (Z102), the BC547a transistor (T101), the 4.7V Zener (D108) and the arm position LED (D109). All of these have now been replaced and the board is behaving just as it should, with one exception. When the arm crosses into the lead-out groove it is supposed to drive the transistor output high which releases the solenoid allowing the arm cue to be in the down position, thus lifting the arm and coincidentally shutting off the motor. With mine, as the cartridge crosses the lead-out groove, nothing happens. However if I move the arm briskly across the same area, the arm cue lifts and the table shuts off as designed.
When repairing the damage described above, I was unable to find an exact replacement LED, so have used a 3mm warm white led with a 3.3k dropping resistor. This seems to be workable although a bit brighter that the original. I can measure the voltage rise on TP4 specified in the service manual, however it doesn't seem to get all the way up to the +15V the manual specifies. It seems to peak around +9V. My meter isn't fast enough to display the voltage when the arm is swung briskly through the lead-out area, but since the auto stop triggers as designed, I must assume that that motion is generating the required voltage to the base of T101 through IC101/3.
Have any of you had / seen / fixed this problem or have any idea what I am missing? I would be deeply grateful for help with this.
Best regards all
Jess
Best regards all
Jess
The whole service manual is published on Vinyl Engine at
Library Downloads - Vinyl Engine
It is in German, French and English
Vinyl Engine does not allow direct downloads of PDF files.
Go here and select "service manual".
Thorens TD147 - Manual - 2-Speed Belt-Drive Suspended Chassis Turntable - Vinyl Engine
R102 trim would tend to adjust LED/photodiode coupling.
The service manual describes a process "Auto Stop Adjustment". Either with a factory gauge or with a 3.5mm rod. Have you done this?
Yes, I have stepped through the auto-stop adjustments detailed in the manual.
I think I found the problem: I decided to look up the specs on the LED specified in the manual and discovered that it is supposed to be an IR diode! The devil IS in the details...
I have robbed an IR LED from an old remote control and will be installing it later tonight. I will let you all know if it works :0)
BTW: thanks for your replies
