I am looking for a 60Hz motor pulley for my Thorens TD145. I moved to the USA and brought my European turntable which has the 50Hz pulley. Does anyone know where I can buy this, I tried ebay and many Google searches, but no luck so far.
Or is there anyone who moved from the US to Europe (or any other 50Hz country) who needs the 50Hz pulley and would like to swap?
Any other suggestions welcome. Thank you!
Lucas
Lucas
Search! you'll find some threads on building a motor controller which results in the right speed with the wrong pulley (and better sound as well.)
MArco
Lucas have a look here....
look at the iPod drive for turntables ...would give you what you need without spending a bunch of cash.
Basically feed the turntable with a ((50/60)X120Hz)= 100Hz) AC signal from an amp that can give you the required number of Watts. (few turntables need more than 25--Garrards, etc).
Re: Lucas have a look here....
Thanks!
Nanook said:look at the iPod drive for turntables ...would give you what you need without spending a bunch of cash.
Thanks!
or you could ....
make or have made a pulley.
(60Hz/50Hz) X (50 Hz pulley diameter) = (60 Hz pulley diameter required).
Or check with Thorens who are now making new turntables, and may have the correct part as a service part.
In a pinch you could also buy some slot car racing wheels (just the wheels). something like this
The pulley size 60Hz@33 1/3rpm x 11mm 60Hz@45rpm x 16mm also have at Vintage Thorens Turntable Parts he may a 60Hz pulley I have gotten one from him in past.
Silvio,
Is yours a standard pulley or the two piece "clutch" pulley? I have a 50hz "clutch" pulley in a friends TD-160.
KC
Hi KC,
Mine is 2 piece "clutch" 50hz. Looking for "anytype" 60hz......
Cheers !!!!
Silvio Finotti
- Analogue Source
- Thorens TD145/TD160 Motor Pulley
