Thorens TD 150 mk2
Well I started to tear this table apart and I found the spindle looking like this. Questions are; how do I clean the shaft of rust, and is there a ball bearing like the Rega, or does this pointy shaft ride on a teflon pad on the bottom on the well?
Thanks, Doug
You may want to ask Whomever you bought that thing from: What happened to the OEM Thorens 150Mk2 Spindle !??.
Cuz that most certainly Isn't one.
REAL one has a captive spherical/ball bearing as the pivot.. not some goofy point.
My td145 had the pointed spindle, no ball. Nice table, looke up "chadwick mods"...adding a ply or mdf bottom plate and some dampening under the top plate really work wonders.
