Hello,
I am cleaning up the Thorens 224 changer and I need some advice. I want to clean and change the oil in the platter bearing shaft assembly. The assembly is the same used in the TD135. How can I remove it? It doesn't have bolts. Is it held down by clips or is it pressed fitted? The strobe lights up but I don't see any strobing when in operation. Any other tips would be appreciated.
Thanks,
David
Thanks,
David
