bhg41088 said:Edit: The crossover is a clone of his active slopes and points, including the notch filter.
But Linkwitz also includes various time delay circuits to bring the drivers into proper phase relationships. He considers this a very important part of the system.
Sheldon
Anyway i can compare the Phase differences between my proposed crossover and his design? What alternations can i make? Also, id rather run one large amp thats 2 channel. I need help!
bhg41088 said:Wow, thats 800$ worth of EQ and Xover right there. I wonder if anyone has done a passive Orion? Would be way, way cheaper.
Doubtful.
Across their pass-band the woofer sensitivity drops about 16dB due to dipole roll-off (2.6 octaves @ 6dB/octave) and about the same from very low Q (Qts = .17, the air in the H-frame raises it a little) for 32dB total. You'll need a much larger and more expensive amplifier to maintain the same output capability with a passive cross-over.
There's a shelving high-pass filter, three shelving low-pass filters, two notch filters, four all-pass filters, two fourth order low pass filters, and two fourth order high-pass filters - all built with 1% resistors, 2% capacitors, and gyrators with those tolerances in place of inductors. Total parts cost in active form with $.10 resistors and $.50-$2 capacitors is about $350 + $100 for the boards (including the $50 recommended power supply and enclosure) and 60W/channel amps are inexpensive from DIY or used sources. Jon's passive Arvo XOs using higher tolerance parts and noall-pass filters (SL believes these to be essential) were $500.
You could physically align the drivers although then it wouldn't be an Orion.
Well, looks like im going to end up going Thor. Maybe one day i can go Orion. I feel bad. Maybe the Phoenix is a good idea. Ill read up.
If you want to try a Linkwitz design with a passive crossover, he has the PMTM1 design.
PMTM1 Page
I am planning to build the PMTM1, then a woffer based on the PW1 design. After I get that working, I want to migrate to active crossovers and a gainclone or 3.
Cost for the PMTM1 don't look outlandish.
Doug
PMTM1 Page
Doug
I have built the Thor and I'm not very happy with the sound. Often, too bright and revealing. I have also listened Orion and they are much better in every area. You may also consider NAO or NAO-AEP dipole design, which has passive HF filtering and active filtering for U-frame woofer.
I wonder why madisound does not offer Trym:
http://www.seas.no/trym.htm
http://www.seas.no/kits main page.htm
It seems like ideal stopgap before going to Orion.
It seems that the Thor is a speaker you either like or dislike. I'm not quite sure why, but they can sound a bit nasty with an amplifier they don't like. I use a diy Aleph 5, which seems to be a very good match.
When my Thor's were brand new they were quite hard and bright, and the drivers didn't integrate very well. So at first I was disappointed with their performance. Fortunately this changed for the better 🙂 But it took at least a month or so before they really sounded "right". This tweeter seems to need an unusually long burn-in period.
That should affect the Orion as well I think..
I don't think you need to feel bad about going for Thor. The Orion is probably a bit better, but Thor is still a very good speaker.
Wow, if you look at the responce and the reviews of the Seas Excel line, they seem very unworth the price. Maybe i should look for something Peerless CSX 6.5 (850122) based, as i love the sound of them open baffle.
I'm not sure where you're reading this. The seas Excel compare very well against the best Scan Speak and other socalled highend speakers.bhg41088 said:Wow, if you look at the responce and the reviews of the Seas Excel line, they seem very unworth the price. Maybe i should look for something Peerless CSX 6.5 (850122) based, as i love the sound of them open baffle.
Hans.
- Thor or Orion
