thomson PA 3015 T
i have a thomson PA 3015 T amplifier that i had to replace its broken STK0039 with an STK0029, it caused the resistance "r634" 22ohm, "r633" 22ohm, on the side in which I've put on to overheat reaching about 160c° in just 10 sec, The temperature decreases as the volume decreases to less, I've also tried to replace it with STK0059 and still had the same issue, keep in mind that i dont have STK0039 to replace it with, and have replaced low Watts output STKs with higher ones with no problems in the past.
There is a resistance removed from the motherboard under a number "r935" and I don't know its value.
