This may have discussed but I tried a few searches and couldn’t find anything. I’d like to add a third input to my B1. Can someone tell me how to do this? I have the B1 PCB from Pass.
You will need to use a multi pole rotary switch. Run all inputs to the switch and from the switch to the board. I believe its the middle set of 6 connecections near the front of the pcb between the volume control connections.
Check out 6L6's pics for another but similar way to do it.
Hi all
I'm also interested in more then 2 inputs for the B1. (I would like 4-6 inputs)
Can anyone recomend a good multi pole rotary switch?
IK
IK
