I've been on the hunt for a thin, fabric-sleeved instrument cable, something in the ~5mm range. The thinnest pre-made cable I've found is from CNZ Audio at 6.5mm. I was going to make my own with Best-Tronics CA-0678 cable, but I'm not sure which braided sleeving material to use - i.e., nylon, TPE, cotton+PET, etc.. Any recommendations?
I know some woven materials can expand and contract a little along their length (e.g., Techflex) to be more fitted.Curious on how will you tightly insert shielded cable inside a thin textile sleeve.
Afaik at the Factory a special machine "knits" separate threads around shielded cable, under tension, so just made sleeve is tight.
Can't imagine that being done at home.
I know you can get heat shrink fabric. Something I found while looking for something else
I do a lot of work with cores to 3mm and some work with cores over 10mm and can pass on some thoughts on those sizes. Sorry, no experience with cores between 3mm and 10. There are two processes. As already mentioned, weaving or braiding around the core. This is best done with a machine and not a result that works long term as it's not compatible with core twist
Preferred is the Chinese finger grip system. The core is inserted up the hollow fabric tube and the tube smoothened over and pull out to shrink over. This grips the core very securely and can also be lessened up to relieve twist. The ends are whipped to secure
Search on 360tuna for posts on hollow core by members Basil, Pametfishir and me, Saqa for tutorials and discussions
You might be able to find Jerry Brown hollow core Spectra in the sizes you want. I have never looked for anything larger than to take 3mm core
Look at places like Mudhole for larger sizes in materials other than spectra. I have used Nylon and carbon fibre for 10mm and larger cores, and also core bundles. Very good alternative to plastic looms. Ends are terminated with whipping, heat shrink and/or cable ties
A solid core can also be inserted into these hollow fabric tubes and laminated with epoxy for hoop strength, but it doesn't do much for stiffness
