I am wondering if any of you gurus can tell me about different names for t/s params. It seems as though some manufacturers use slightly different names (as in Re) for the different parameters. This is unclear to me as I am new to this. I would like to use speaker workshop to model box/crossover design. I have built a few boxes based on T/S and done ok but it looks as though in the crossover is were it is at.
Please go easy on me as I am unknowing but willing to listen and learn.
Thanks Shane🙂
Thanks Shane🙂
Re is the simple resistance of the driver, measured when you unhook the driver from the amp and just measure the resistance between the speaker terminals with a multimeter. It is also labelled DCR.
Vas is sometimes called "equivalent volume".
Be careful of this one: excursion. Linear excursion is the amount of travel the speaker can do without going into distortion. It is supposed to be measured from the center to the extreme. So a driver with 6 mm linear excursion is supposed to be able to go from rest to a point 6 mm forward and back to rest again linearly. This is also sometimes called "peak excursion", not "Peak-to-peak".
However, some manufacturers list their excursion as being "peak-to-peak". That means the distance traveled coming all the way back to all the way front. This way of measuring yields a number twice as large as the normal way to state linear excursion.
Then there is Mechanical excursion, or max mechanical excursion, which is how far the driver can go without suffering mechanical damage, regardless of the distortion. In hi fi drivers it is safe to assume that Mechanical excursion is at least 1.5 times the linear excursion, usually somewhat more. PA drivers can have mechanical excursion four times the linear excursions.
Any others you would like to list?
In regards to Xdam (maximum mechanical exursion).
If you have the air gap height and the voice coil height you can calculate the Xdam by subtracting the former from the latter. This is the peak-to-peak Xdam or Xdam(p-p).
This is not an exact figure but can be used if it is not spefied on the parameter sheet.
The following are the main parameters listed in a somewhat abbreviated form to allow you to interpret most parameters correctly. Different manufacturers may modify these terms slightly, and they may use different units (like cubic meters instead of liters, etc..) So you have to be aware of a lot of things.
Major Variables:
F = frequency
Q = Q factor
V = Volume
S = Area
R = Resistance
L = inductance
C = capacitance or compliance
M = mass
Subscripts (Modifyers):
a = acoustic
s = speaker
e = electrical
m = mechanical
t = total
c = combined (or sometimes closed box or cutoff)
b = box
l = loss
p = port
d = diaphragm
vc = voice coil (seen sometimes with R and L - equivalent to "e")
Some examples:
Fs = Resonant frequency of speaker
Fb = resonant frequency of box
Fc = combined box/speaker resonance (for sealed - also called Fb in some texts)
Qes = Q electrical of speaker
Qec = Q electrical of speaker box system (closed speakers)
Vas = Equivalent acoustic volume of speaker compliance
Re = electrical resistance
Le = electrical inductance
Sd = diaphragm area
Major Variables:
F = frequency
Q = Q factor
V = Volume
S = Area
R = Resistance
L = inductance
M = mass
a = acoustic
s = speaker
e = electrical
m = mechanical
t = total
b = box
l = loss
p = port
d = diaphragm
Some examples:
Sd = diaphragm area
T/S
Thanks for all of your input!!
It looks as though the program is asking for:
Voice coil series (L1)
Voice coil series (R1)
If I am correct from the info given L1 should be the equivalent of Le
and R1 should be Re correct ?
Thanks Shane
Thanks Shane
454Casull said:All this time and I still haven't figured out what Q really means...
I believe its from radio circuits where very narrow filters were
required, Q's of >100, and that Q is an abbreviation of Quality
Factor related to the peak value and the width of the radio filter.
Doesn't make much intuitive sense when applied to loudspeaker Q's.
🙂 sreten.
Q = energy stored/energy dissipated (defined at resonance).
Speaker workshop uses a slightly enhanced driver model, which consists of a fixed inductance and resistance, in series with a component that consists of an inductor and resistor in parallel. Look for help on "set equivalence", although this may confuse you more because the nomenclature is inconsistent. The best thing to do is measure the driver with speaker workshop and let it do it's thing. L1 and R1 (and Re and Le for that matter) are under the heading "calculated", so you don't need to enter these. The model is still a rough model of driver inductance (measurements are better) and cannot fully account for the variation in inductance with frequency, and there is no way to guess values for the extra components.
The only reason to enter Re is if speaker workshop is indicating really wacky values, in which case the other measurements may be suspect as well.
What are the general opinions on this model? I have seen this, and also another where the impedance of the inductance goes like
Zl=w^n * L, where n usually is 0.6 .. 0.8 for most drivers.
(The normal inductor would of course be Zl=w*L)
Has anybody tried to match either or both of these models to real driver data?
sreten said:I believe its from radio circuits where very narrow filters were
Think you are close by. It means “Quality factor” but tells you nothing about the actual overall quality of the speaker. In radio circuits it says something about the frequency discriminating capabilities of a tuned circuit.
A loudspeaker is a mass-spring system and also a tuned system in some sense. Same laws apply. It tells something about the inherent capabilities of the speaker how quickly the fundamental resonance (Fs) dies out. The total Q factor Qt is the inverse of damping factor D. Damping factor comes from control theory and feedback systems, but since loudspeakers are handled mostly by EE’s (like Thiele and Small) which are more familiar with Q they keep using Q. Qt is the total result of mechanical damping (1/Qm) and electrical damping (1/Qe).
Cheers 😉
What are the general opinions on this model? I have seen this...
See:
http://www.linearx.com/products/software/LEAP5/EnclosureShop/EncShp05.htm
I believe the "conventional model" is the either the model described above or just a Le,Re model. I know the middle one is a power law model, and the LTD one is LEAP's new model, they may have more info on it at their website.
There are a lot of comparisons to measured data at the link.
IME, speaker workshop's model is not a very good fit to woofer data. I solved that circuit and wrote a spreadsheet to extract the two inductances and two resistances and found it was not a very good fit on some drivers.
Is there other software that models crossovers as well as boxes similar to Speaker Workshop? As this is the root of the reason I had made this thread. I dont want to pay for some software and not have it do what I want. I do understand "FREE" usually implies high learning curve and that is fine but paying $1300.00 for LEAP is out of the question.
I would like good crossover modeling so I can do impedance type compansation as well as other crossover enhancments.
Thanks Shane
You misunderstand. Speaker Workshop is fine, there is nothing wrong with it. The "driver equivalence" is just an academic thing, it is not used for any calculations in box or crossover design that I am aware of. I don't even do the "set equivalence" and things come out fine.
Design your crossover or box with measured impedance and frequency response data and you will be fine.
T/S parameters using Speakerworkshop
Hello,
I came across this thread when I searched for ways to get TS parameters using Speaker Workshop.
I thought this would be an appropriate thread to post my query..
I have set up the Speakerworkshop software and calibrated it to measure Resistance, Capacitance etc of Passive components quite accurately.
Now I want to measure the TS parameters of a couple of Woofers I have with me.
The TS Parameters specified by the manufacturer are not available with me , and neither can I get it from the manufacturer.
SO I got the Impedance measured in free air and Impedance with added mass.
But when I make Speakerworkshp to estimate parameters, it does not give me any different readings from the default parameteres the software assigns to any Driver when you create it in the Project.
So I set all the parameters in the Properties->parameters page to 0 and then reestimated using the Impedance measure in free air and with added Mass. But no outcome.
Could any one tell me what I am missing and how I can get Speakerworkshop to calculate the TS parameters? And are there some bare minumum parameters which I have to enter manually?( now all parameters are set to 0 as I dont know any. I can measure and find the Sd Btw.)
Please help.
Thanks,
Linoj Job.
Hello,
Please help.
Thanks,
Linoj Job.
Re: T/S parameters using Speakerworkshop
Make sure you go to the "data" tab in the dialog box you mention and select the proper measurement files. You click on the question mark and select the proper impedance file. I don't think you actually need any of the inputs on the parameters page except for Sd - because the added mass method uses Sd. You will only need the others for box modeling purposes. Once you have all that done, you can calculate parameters.
Could any one tell me what I am missing....
Re: Re: T/S parameters using Speakerworkshop
Thanks a lot for the directions..Shall let you know once I measure on the weekend.
Linoj Job.
claudio said:Hi,
check my HP, I think you will find some answers on SW.
Claudio
Linoj Job.
- Thiel Small Parameters?
