Theta Data III loading problem solved
FYI, my Theta Data III traport started giving hassles-basically the sled motor would continue running even after the tray was fully loaded.
Problem was that the CD was not being clamped and further
investigation and also advice from a US repair shop showed the problem to be a slipping load belt.
Replaced this and everything is working again.
Also, for the record, the Data III is a modified Pioneer CLD-99, I have the circuit diagram.
