Theoretical SPL vs distance
Ok, if I remember correctly:
My A7 boxes are 97 dB with 1 watt/ 1 meter
My A4 boxes are the same.
Each running at one watt (2 watts total) = 100 dB
Around the 2048 watt mark I should reach the magical 130 dB plateau.
Now, how do I calculate the what the SPL drop is from being further from the speakers. I wish to know what the dB level is at 10 meters. This is in open air, no room gain.
Is there a formula or does it have to be measured because of differing dispersion patterns and other factors?
I think I just answered my own question.
Cal
It depends on what BW you use to measure efficiency, but an A7/A4 in the majority of their BW are 104/107dB/W/m with Altec drivers, so are the woofers you're using that much lower eff.?
Anyway, sounds falls in free air at 6dB/doubling of distance, so using 97dB and 10m:
dB = 97 - (20*log10 (1m/10m)) = 77dB
at 2048W:
77+(10*log10 (2048) = 110.11dB/10m
Really, due to your tall stacks, it's best to measure fairly far away where the soundfields have 'jelled', then calc backwards to find the real 1m eff.. The old standard, and one that is still used by some in the prosound market is 0.001W/30ft, though 10m is within 0.78dB, so will work well also.
Note that due to atmospheric conditions and the decreasing acoustic pressure with increasing frequency, it falls quicker up in the HF. WRT off axis power response, you'll have to measure it.
GM
Thanks for your responses. I have a pretty good handle on it now. I didn't know it was calculable.
GM,
You've always been a big help with the Altec stuff, maybe you can help again.
If you remember, I am using this woofer:
15"
And this tweeter on the 511B on the A7 boxes:
1" comp
The tweeter is heavily resisted (resistored?) to make the two match.
I am simply guessing at the 97dB.
Might it be more?
I have no way of measuring anymore. The only SPL meter I owned was the Radio Shack one about 25 years ago.
Thanks for your help,
Cal
These aren't a good match to either cabs, but can be FR shaped with digital EQ. In the A4s, they would have ~99.81dB/2.83V/m in half space if wired in parallel, plus the ~7dB horn gain beginning around 100Hz. Since these are outdoors, subtract 6dB, or ~93.8dB ramping up to ~100.8dB/2.83V/m.
The A7 will be down to ~88dB/W/m outdoors, ramping up to ~94dB/W/m, not including whatever the ground plane adds, which won't be a lot IIRC, but I lost my outdoor measurements in a house fire in the early '70s.
I still use a 1st generation RS SLM, though it requires a correction factor.
GM
Cal
This is not what you wera asking about, but playing the two speaker simultaneously doubles sound pressure, ie + 6 dB. So running both at 1 watt each you end up with 103 dB, not 100 dB.
Yes, the efficiency is doubled, at least for low frequencies where there is no cancellation in any direction.
Adding amplifier from 2 to 2048 Watts, will increase the level by 10*log(2048/2)=30 dB, so you are now at 133 dB.
If the speakers are point sources (not line sources), the level drops by 6 dB for each doubling of the distance, or Lf=Lc+20*log (dc/df) where Lf/Lc are far/close levels, df/dc are far/close distances.
If df=10 m and dc=1 m level will drop by 20 dB, to 113 dB.
All under the conditions low frequency, free field, and point sources.
hi
cal , ill go with gm -
given a few things subject to present conditions (though you have mentioned free air)
for the tweeters if ure interest lies in removing the resistor to improve spl - they act as to protect your tweeter too - to in simple terms route - more current through ure lo drivers
- thank god altec didnt model anything on the animal world - (frogs) it would be difficult to put in a reply then !
take care
suranjan
No time to comment, but you all are are forgetting directivity. Most soeakers don't radiate fullspace, and for a significant portion of their bandwidth they radiate into much less. Look up "Directivity Index" in the sound system design manuals at JBLpro.com.
phase_accurate said:
But they would still be loud enough to annoy the whole quarter. 😎
Charles
Oh Ya.
take care
suranjan
The resistors have to stay to match the woofers
Frogs? Who would ever imagine anything like that I wonder? 😉
Thanks again,
Cal
